Author Topic: Diverter valve  (Read 3318 times)
Say bye bye
Diverter valve
« on: 15 March 2006, 21:56 »
How much noise is the diverter supposed to make?? mines makes a VERY noticable fluttering noise been told this can meen it needs replacing??
Also what you guys think of this?? >
http://cgi.ebay.co.uk/GFB-Hybrid-Blow-Off-Valve_W0QQitemZ8009296930QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
its 50% recirc 50% blow off from what i can tell..
Offline >>Mart<<
Re: Diverter valve
« Reply #1 on: 15 March 2006, 22:58 »
thats a bit expensive really i got a forge one for 110 which you can change the springs on if you ever up the boost it is a bit noiser than the standard one but i did not want a noisy one anyway
usually the standard diverter valves rubber diaphragm perises like mine did
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Diverter valve
« Reply #2 on: 15 March 2006, 23:05 »
Forge all the way. Dump for show, recirc for go! :grin:
« Last Edit: 15 March 2006, 23:18 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Say bye bye
Re: Diverter valve
« Reply #3 on: 15 March 2006, 23:13 »
how can ou tell its gone?
Re: Diverter valve
« Reply #4 on: 15 March 2006, 23:17 »
My chattering just got increasingly worse, & the car seemed to keep getting more & more sluggish. Had it swapped under warranty, though, so even VW techs agreed. :laugh:
(The rubber diaphragm inside just tears)
Say bye bye
Re: Diverter valve
« Reply #5 on: 15 March 2006, 23:19 »
that fluttering noise has gotten louder... and does seem sluggish... ok so got any links for the forge one people are highly recomending??!
Re: Diverter valve
« Reply #6 on: 15 March 2006, 23:42 »
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0006&product=FMCL007P
This is the one I've got ^^^^^, but i think you can get it cheaper elsewhere, though.
Ask for a length of silicone vaccuum hose to go with it, though, as your OE one will more than likely be brittle/cracked/holey & will be a bugger to get it to slip over that top connection piece of the Forge.
Try Awesome & VW Speed for prices.
Offline Scott_1.8T
Re: Diverter valve
« Reply #7 on: 16 March 2006, 18:54 »
Do you get any more chatter with the Forge one, cos I love that sound?!
Re: Diverter valve
« Reply #8 on: 16 March 2006, 20:08 »
Only (noticeably) get it when I've got my BMC I.K. on!
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Diverter valve
« Reply #9 on: 16 March 2006, 20:11 »
The recirc valves are not designed to "chatter", although they will make a bit more with an induction. if you want loads of noise then buy the one in the ebay link above, that will make loads of noise :grin: :grin:
