Author Topic: Rocker cover takeoff  (Read 932 times)
Offline golfmk2boy
« on: 15 March 2006, 20:11 »
Hi,
I need to take rocker cover off to check my cam.  I just need to know what is involved, do I have to do any prep before taking the thing off?
cheers!
Offline mk2_singh
Re: Rocker cover takeoff
« Reply #1 on: 15 March 2006, 20:20 »
YEH PRETTY straight 4ward. just clear the hoses n pipes that run over the rocker cover. you dnt have to but will make life easier in step two.
step two unbolt the rocker cover and remove.  :tongue:
pretty straight 4ward as i said. why do you need to check the cam anyway? its going to pointless opening it up like that to check the cam. You wont really know what your looking for?  :undecided:
Offline golfmk2boy
« Reply #2 on: 15 March 2006, 20:26 »
I need to look to see whether the cam is modified.  Im having problems with pinking which obviously is related to timing.... Just a vw racer thinks it has.. I need to take it off to fit a new gasket anyway.
Also need to find out what the oem oart number is for a standard cam as I believe it is printed somewhere on it.
..... only going to take it off when the new gasket comes from ebay.
Thanks for help so far matey!
