Author Topic: removing a starter motor  (Read 1346 times)
Offline MJF44
« on: 14 March 2006, 17:03 »
hello. today I have tried to remove my starter motor (1.8 20v) but after removing both bolts either side at the front it would not budge, even when coaxed with a tap from a hammer. Is there another bolt somewhere holding it on that I can't see? any advice much apreciated.
Say bye bye
Re: removing a starter motor
« Reply #1 on: 14 March 2006, 22:01 »
Im fairly sure most starters come with 3 bolts... havnt tried takin any off a golf   :undecided: you tried having a feel round??
Offline kniterider
  • had most, sold most and often buy more!
« Reply #2 on: 18 March 2006, 19:01 »
sure there 3 have another look..... if your removing to check stuff cause of the dreaded 'wwwrrrr' noise on start up u need some copper slip grease to bung on the brass bush in the gear box and to put on others in the starter if you strip it...asy job though...
 :smiley:
