Author Topic: Broken Oil Breather  (Read 2802 times)
Offline LGTI
Broken Oil Breather
« on: 13 March 2006, 23:32 »
Whilst replacing the rubber (top) section of my oil breather pipe I managed to snap the long plastic section that goes into the engine. It has snapped at the point where it enters the engine (mk3 2.0 8v).
Can anyone tell me how I replace this pipe as I cant see how I can completely remove the section that goes into the engine? i.e. how is the section that goes into the engine secured?
Any help much appreciated.
Thanks.
Offline carl
Re: Broken Oil Breather
« Reply #1 on: 13 March 2006, 23:59 »
there is a big clip holding it secure right at the end of the tube just before engine
just pull it out and job done.
Offline LGTI
« Reply #2 on: 14 March 2006, 00:08 »
Would that be the green metal clip?
I pulled this out but nothing seemed to have come loose??!!
Offline carl
« Reply #3 on: 14 March 2006, 00:12 »
yes thats the one
just give it a good tug
i broke my one the same as you.
Offline LGTI
« Reply #4 on: 14 March 2006, 00:14 »
Thanks, I'll give that a go. How much you pay for a new pipe?
Offline carl
« Reply #5 on: 14 March 2006, 00:21 »
got one from scrapyard for £2 as they are a bit expensive cant remember how much,
there is a rubber washer that seals it you will see it when you pull the pipe out,
 just make sure you put it on new one .
hope this helps
Offline LGTI
« Reply #6 on: 14 March 2006, 00:28 »
Just to confirm, how did you get the remainder of your broken pipe out? Tired pulling mine out with a set of mole grips (as it has snapped right at the end where it goes into the engine), but it was just pulling bits off the piece that was still attached.
Thanks for the help. Much appreciated.
Offline carl
« Reply #7 on: 14 March 2006, 00:40 »
my pipe broke in the middle so it was easy to get out,
it does not go in far so you should get it out with a screw driver,
sorry for not been anymore helpfull
Offline LGTI
« Reply #8 on: 14 March 2006, 00:42 »
Thanks for the help mate, I'll have a proper look at it tomorrow.
Offline carl
« Reply #9 on: 14 March 2006, 00:44 »
no problem :smiley: :smiley:
