Author Topic: mk2 vr6 conversion  (Read 1129 times)
Offline mk2 _8v_sunderland
mk2 vr6 conversion
« on: 13 March 2006, 22:11 »
just wonderin if anyone has tips on doin a mk2 2.9 vrs conversion as i a m considering doin one?
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Offline ...joe
Re: mk2 vr6 conversion
« Reply #1 on: 13 March 2006, 22:31 »
a few people on here are doing them but i guess the best advice is get as much of the donor car as possible, you'll need upgraded brakes suspension etc its easy to bodge but done well its wicked!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline mk2madman
« Reply #2 on: 14 March 2006, 12:05 »
If as your user name suggests the car you are using is an 8v then good luck!
You want a rear ended rado??
Take the entire front end with cross member! looms, fuse boxs & everything!
Then check the posts for changing hydraulic cluch to cable clutch?
then save a lot of cash for top of the range suspension Brakes and handling upgrades?
and then bolt it up to your 8v?
easier and may be better/cheaper option would be 2.0 16v
but that is just my opinion
Offline Veedub1989
« Reply #3 on: 14 March 2006, 13:42 »
try....
http://mk2vr6.com/site/news.php
really useful site  :grin:
VW Golf 1989 2.0L 16v
Offline Outlaw-Torn
  • Let me try that again, with a bit less stupidity..
« Reply #4 on: 15 March 2006, 23:58 »
I agree with mk2madman, stick a 2 litre mk3 in there! I had a mk2 with a mk3 engine (till someone drove into it) was stupidly fast! 0 -60 in about 6.5 seconds, the guy i got to fit it reckoned putting a VR6 in wouldn't really be any quicker, cos it's so much heavier. Plus if you've got a 16v mk2, the mk3 engine'll go straight in, only sits 1mm higher and runs on same injection system, so just upgrade the brakes, lower the car a little bit and the job's a good 'un!
'I've got your mother's maiden name tattooed on my arm...'
