Author Topic: Bolt on Air filter kits  (Read 3363 times)
VeeDubGTI16v
Re: Bolt on Air filter kits
« Reply #10 on: 14 March 2006, 15:45 »
whys everyone telling him to do the gti box mods when hes got a carbed driver :grin:
Offline Agreeable Slick
  • Unit
« Reply #11 on: 14 March 2006, 15:55 »
Cos drivers still have the piping leading down to an airbox down on the drivers wing. Either that or i am very confuddled.
Offline T_J_G
« Reply #12 on: 14 March 2006, 17:34 »
Correct Slick.
and thanks for your help!
 :smiley:
VeeDubGTI16v
« Reply #13 on: 14 March 2006, 20:43 »
mine had the filter in a box above the carb :huh:
Offline Haribo!
« Reply #14 on: 15 March 2006, 01:28 »
you should have a flimsy pipe that connects your main airbox to a silly airbox thing on the wing, but they often missing
« Reply #15 on: 15 March 2006, 08:05 »
Nope, the airbox is ontop of the carb itself.  Drilling holes in it would increase your engine noise, but also the ammount of warm air sucked in from the engine bay, not that it matters that much on a driver as the warm air feed is open 99.9% of the time anyway!
Offline roverspeed
« Reply #16 on: 15 March 2006, 19:41 »
i drilled my drivers air box, took the stupid piece of piping that goes into the wing, left the piping that goes to the exhaust manifold, when summer comes i have a some cold air feed i'll run to where i have drilled the holes,
Makes sweet f.a difference to performance, but sounds louder and more throatier under full throttle, especially under load, ie up hills.
  • Unit
« Reply #17 on: 15 March 2006, 20:22 »
I have seen driver engine bays with the piping leading down to a box on the wing, albeit not as bigger box as on the GTIs but still there.
« Reply #18 on: 16 March 2006, 09:11 »
That'll be a MK3 Driver with an SPI unit :)
Offline roverspeed
« Reply #19 on: 16 March 2006, 11:21 »
i have a mk2 1.6 driver, and there is piping leading down to the right wing
