Author Topic: Front wings  (Read 2845 times)
Blue MK2
Front wings
« on: 22 November 2003, 20:56 »
Does anyone know how much a LH front wing for my 8v would cost new.
Are these easy to replace and how?
I wont attempt changing the wing if its welded in.
Thanx in advance
Offline Davo13
Re:Front wings
« Reply #1 on: 22 November 2003, 20:59 »
Euro car parts sell them for ?16.40 plus vat.
Blue MK2
Re:Front wings
« Reply #2 on: 22 November 2003, 21:50 »
Are they originals or pattern parts?
Offline m4nesh
Re:Front wings
« Reply #3 on: 22 November 2003, 22:05 »
the wings from eurocar parts are really sh!te...very different from the original in quality....go see a vw breaker
Offline jedi16v
Re:Front wings
« Reply #4 on: 22 November 2003, 23:05 »
quite easy to fit bolt on items . which is nice . the mr volkswagon !!!
Offline modulater
Re:Front wings
« Reply #5 on: 23 November 2003, 01:07 »
Dont ever fit pattern parts as they look really crap and are made out of really thin metal so the build quality is poor.
If you want an original wing for ?50 try the following.
http://www.gpcvwaudi.com/
Original VW bits at cheap prices. I've used them for a lot of things and they are excellent.
action al
Re:Front wings
« Reply #6 on: 23 November 2003, 10:05 »
There is no welding needed just bolts. As said before don't get pattern panels as they are sh*te. I searched around by phoning all the vw breakers and managed to find a front wing in good condition in the correct colour. all for ?15! can't argue with that! Took about 2 hours to fit it up properly!
Offline richandhazel
Re:Front wings
« Reply #7 on: 23 November 2003, 11:46 »
I'd go along with the above too. I'd always rather use VW or GPC rather than use pattern wings. The cheaper alternative is to pull an original wing off a car at the breakers........can be a bit of a nuisance if you're doing it yourself as although the wings are 'bolt-on' the amount of underseal and protection they put on the underside means that even with all the bolts removed, they stick like sh!t to a blanket...........worth the effort though, much better than a pattern one.
Blue MK2
Re:Front wings
« Reply #8 on: 23 November 2003, 11:50 »
Cheers peeps ;D
