Author Topic: ABS Sensor  (Read 2297 times)
Offline dicksparks
ABS Sensor
« on: 22 November 2003, 20:19 »
Had a damaged abs sensor which i have replaced abs light still on does the abs computer have to be reset  if so is this a garage job only or does somebody know how to do it thanks
golfvr6
Re:ABS Sensor
« Reply #1 on: 28 November 2003, 00:04 »
Is there damage anywhere else in the system? did you check the rotor when you replaced the sensor? Unfortunately the ABS system is beyond the scope of the DIYer except checking for physical damage. If the system requires a reset then you will probably have to go to VW.
