Author Topic: Help, 8v wont run!  (Read 1185 times)
Offline Kinetic Dan
Help, 8v wont run!
« on: 09 March 2006, 17:57 »
Hi, i have an '87 8v, which recently died on the M3 motorway, much like it had run out of fuel, although it hadn't.
I checked, there is spark, but fuel is not getting to the injectors. I checked connections to the metering head, fuel is getting it, and down to the part which looks like a pump on the front of the engine block, and back up to the metering head. However I loosen off any of the four braded lines on the meter head, no fuel comes out when the engine is cranked. I've taken the meter off and stripped it down for any obvious sign, can anyone help as to the problem?
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
Re: Help, 8v wont run!
« Reply #1 on: 09 March 2006, 18:15 »
pump on engine is a kjet and would deffo go straight for that.
Offline Kinetic Dan
« Reply #2 on: 09 March 2006, 18:35 »
I did suspect that, but the fuel is pumping back up the return when I spin the engine?
Offline FBF
« Reply #3 on: 09 March 2006, 21:55 »
i had similar problems so i swapped the ecu with one from a nother car.  it cost me nothing to cheack and it solved the problem.  might be something to try sooner rather than later.  dont know if it'll work but it could be related
Offline Kinetic Dan
« Reply #4 on: 10 March 2006, 14:50 »
k-jet 8v doesnt have an ECU?
The local VW 'specialist' reckons its the metering head?
« Reply #5 on: 10 March 2006, 18:45 »
Sounds like a metering head fault to me, what happens if you lift the flap manually when cranking?  Haynes has a section on how to set the flap properly.  The bit in front of the airbox will either be a fuel filter or accumulator, the main pump is under the car.
Does the pump prime when you turn the key?
Offline Kinetic Dan
« Reply #6 on: 11 March 2006, 17:18 »
When uncliping the airbox lid and cranking the engine, I can feel the flap jumping up and down. When pushing the flap upwards, nothing changes, not even a cough or splutter...
Offline Kinetic Dan
« Reply #7 on: 12 March 2006, 18:59 »
Anyine have any more advise? Cheers
Offline filthy
« Reply #8 on: 27 January 2007, 19:52 »
This is whats happening to mine- please anyone got any ideas? I was gonna put an air line into the main feed hole and try to blow any sh!t out
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
