Author Topic: Electrical problems, fuse box f**ked  (Read 7407 times)
Offline GemGTI
  • Gemma
Re: Electrical problems, fuse box f**ked
« Reply #10 on: 06 March 2006, 21:19 »
Thanks for all your hels guys. Just looked on euro and vw spares websites, and their fuse boxes are loads cheaper. I'll phone them in the morning. Thanks again  :smiley:
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #11 on: 06 March 2006, 21:23 »
 :nerd: check for leaks first  :nerd:
I've just checked eurocarparts website and couldn't see them listed  :sad: they definately do them though so they're worth a ring 0208 697 8805, they do mailorder  :smiley:
To be honest, I've replaced 3 fuseboxes (4 if you count the one that got soaked 2 days after fitting  :angry:) and I've never had a fire  :smiley: (ok once but that was an exhaust rubber :wink:) they just wont start  :angry: :cry:
If you can get it home, remove the tray under the dash so you can see the fusebox as well as possible and get someone to run a hose over the front of the car (and sunroof if you've got one) while you watch for leaks.
 :huh: You haven't mentioned if the fusebox is still wet now???
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline GemGTI
  • Gemma
« Reply #12 on: 06 March 2006, 21:40 »
No its not wet now but it could have got wet as my car does leak. Keep meaning to check the sunroof but haven't got round to it yet :rolleyes: and I do have those little holes from previous wiring for the stereo through the scuttle area? If that makes sense? (I don't know If I am using the right words!  :embarassed: )
« Reply #13 on: 06 March 2006, 23:15 »
fill those holes while its dry, even a bit of gaffer tape will do for now (stern teacher like smiley needed :smiley:) that way you can check the sunroof, which with any luck will be ok. Then you can just pop round to your welder's and get those holes filled and you're sorted  :smiley:
my dub project:-
