Author Topic: how do you remove the interior boot cover?  (Read 1499 times)
Offline Mr Blue
« on: 04 March 2006, 22:18 »
how do you remove it without damaging anything :rolleyes:
only found 2 screws in the grab handle bits :sad:
me fookin boot lock is abit dodgy and keeps setting the alarm off :angry:
Offline Rhyso
Re: how do you remove the interior boot cover?
« Reply #1 on: 06 March 2006, 11:42 »
start on the left hand side and gently but firmly prise the trim cover off.  work your way around the edges as it is held in several places by clips.
Got to do this myself lunchtime as there is water getting in; could be  the rear washer pipe come loose / split - they are prone to failing  :sad:
look for the micro switch and clean it out with WD40 - should sort it  :undecided:
