Author Topic: 16v clock faces  (Read 5321 times)
Offline ashmk1
16v clock faces
« on: 10 May 2003, 13:46 »
Hi chaps, Can i put 16v clock faces on my standard mk1 1800 clocks!!?
cheers ash mk1 16v cab
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
old_boy
Re: 16v clock faces
« Reply #1 on: 11 May 2003, 11:18 »
Dont think so, due to calibration, much easier to put whole speedo in like i did.
I have a 16v speedo for cheap if you fancy. :D
Offline ashmk1
Re: 16v clock faces
« Reply #2 on: 11 May 2003, 19:21 »
Can i just change speedo cable!! or do i need 16v clocks?
cheers
ps: how much?
cheers
ash mk1 16v cab
wales
old_boy
Re: 16v clock faces
« Reply #3 on: 11 May 2003, 20:39 »
howdy!
you can use your speed cable and everything else fits just right-you need the plugs to adapt the wiring (which i have) when i put it in my old mk1 16v i had everything wired and working as it should apart from the mfa (didnt bother) if you want it, its yours for ?10+p+p VGC!
Offline ashmk1
Re: 16v clock faces
« Reply #4 on: 12 May 2003, 15:28 »
Have you got 16v clocks for sale m8!!?
cheers
ash mk1 16v cab
wales
