Author Topic: Clutch goosed???  (Read 2249 times)
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
Clutch goosed???
« on: 02 March 2006, 21:04 »
In the summer of last year I fitted a nedw clutch plate as it was slipping when I was pulling off from rest. Over the last few months I have started to struggle to engage 1st and second gear and more recently, its started to crunch in reverse and sometimes when goingt into 3rd.
Has anyone had similar problems or can anyone help me out please. Many thanks
Ronnie
Offline Tucker
Re: Clutch goosed???
« Reply #1 on: 02 March 2006, 21:25 »
check the gearbox oil level and slector bushes :wink:
cheers
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline mk1
« Reply #2 on: 02 March 2006, 22:34 »
Check the clutch adjustment, the pedal should be about the same level as the brake.
Steve.
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #3 on: 02 March 2006, 23:43 »
This sounds like your gear linkage needs adjusting as if the linkage is out by a little bit - your have alot of issues with getting all gears and reverse will be issue.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline ronnie'C'
« Reply #4 on: 04 March 2006, 10:28 »
Cheers all, going to have a play with it today and new bushes are on demand.
Offline Phil303
« Reply #5 on: 04 March 2006, 13:20 »
It could be your engine mounts. If these are worn or broken, the slight shift could have an effect on the gear selection link arms. I had first gear problems and was convinced it was the 'box or clutch. Turns out it was the much-cheaper-to-repair engine mounts.
Good luck.
Offline ronnie'C'
« Reply #6 on: 05 March 2006, 09:18 »
cheers Phil, i will keep that in mind.
