Author Topic: Replacing a Battery in a 20vT  (Read 1468 times)
kompliance
« on: 02 March 2006, 12:01 »
Hi all,
I have done a search and nothing came up so here goes;
Is there a trick to removing the battery from a 20vT? My battery has died this morning and I have a replacement waiting to go in but I cannot get the bugger out!
There are four size 10 spanner bolts on the top and on bolt on the base of the battery I have taken off. However there is a load of wires/fuses on the top of the battery and a metal strap underneath preventing it from going anywhere. There really is no space to work on under the bonnet :(
Any help appreciated!
Thanks
Rich
Offline richy
  • neeeeeeeowm
Re: Replacing a Battery in a 20vT
« Reply #1 on: 02 March 2006, 12:49 »
It is a bit of a bugger.  Take the cover off the head lamp case to give yourself a bit of room.
You've done the right stuff so far.  The bolt at the bottom is what holds it on.
If it's the same as my1.8 20v (not turbo), and I remember correctly, you've just got to lever the metal strap thing off the top of the battery (try pressing down the top - it is just hooked over the ridge on the battery)
I might be talking total cr@p, cos I can't see it right now ( I'm at work and my car is outside in the snow - no way I'm going out there unless I have to!! )
« Last Edit: 02 March 2006, 12:52 by richy »
54-plate Golf 2.0 FSI GT.  Leather interior.
kompliance
« Reply #2 on: 02 March 2006, 13:34 »
Right i'll try that when I get home.
I left the terminals off the battery this morning, that shouldn't cause any troubles should it?
kompliance
« Reply #3 on: 03 March 2006, 11:12 »
Sorted, thanks for your help!
I replaced my battery with a calcium one from halfords, however the base of these batteries is differant and will not secure in place properly. I bought a larger bolt (M8 in size) and used this to fasten the clip on the base of the battery in tight.
