Author Topic: MFA trip computer faulty + engine rattle  (Read 1690 times)
Offline AdamGT
« on: 02 March 2006, 00:04 »
Hi there people. Just bought a Mk3 Golf GTI; great car, really pleased with it but for just a couple of things. When driving down the M6 the other night, the Trip Computer (MFA) display decided to completely switch off, just died! How do I get it back working again? The mileage reading on the other display also has a bar missing on one of the numbers, so it might be an electrical fault on the whole instrument panel? There's not a fuse for those displays either as far as I know?
Also, there is a slight rattle coming from the engine when I accelerate, generally up to 3500 revs, then its quiet. I'm hoping its not the timing chain, any ideas?
Cheers!
« Last Edit: 02 March 2006, 16:45 by AdamGT »
Offline vwagain
Re: MFA trip computer faulty + engine rattle
« Reply #1 on: 02 March 2006, 18:16 »
Fuse number 21, 15 amp. It runs the MFA, interior lights, cig lighter, central locking,clock,. Mines been playing up with the cold weather. Someone had put a 10 amp fuse in!!!! I replaced it with the correct 15 amp and its been fine since.
Stu
1996 2.0l 8v, black magic pearl paint<br />
Offline monkeyalan
« Reply #2 on: 02 March 2006, 18:51 »
Cheers!
probably the heat shield on the exhaust downpipe. common problem, hard to fix. some have ripped it off, some have put jubilee clips round it, some have hit it with a hammer, others have just lived with it.
Offline AdamGT
« Reply #3 on: 02 March 2006, 19:41 »
Thanks for the suggestion about the heat shield, I'll check that out. I could live with it I suppose, as long as its nothing serious.
I just tried replacing the fuse. It had a 15Amp fuse in it already and even when I replaced it, the display was still blank. So no joy.
Offline monkeyalan
« Reply #4 on: 02 March 2006, 19:47 »
not serious , just annoying. It may well just dissappear , mine did, twice. touch wood.  :wink:
MFA sounds like an auto electrician job unless a VAG com or fault code reader can diagnose it.
good luck.
