Author Topic: 1.8T Error codes  (Read 4220 times)
Say bye bye
1.8T Error codes
« on: 28 February 2006, 20:28 »
Was wondering if anyone can help me out with these i have run diagnostic, these are the codes and what they mean... but its all gibberish to me  :huh:... any ideas on what i need do to?
16486 (P0102)   Mass or Volume air Flow Circuit Low Input
      INTERMITTENT
17608 (P1200)---Unknown Trouble Code
17748 (P1340)   Engine RPM Sensor Plausibility
      INTERMITTENT
VAG-COM Version: Release  311.2-N
Control Module Part Number: 06A 906 032 DR
  Component and/or Version: 1.8L R4/5VT         0002
           Software Coding: 11500
            Work Shop Code: WSC 00000
1 Fault Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
        P1200 - 35-00 - -
The engine management light is on and to me, the turbo doesn't seem to be giving as much kick as it used to.. any ideas on what i need to change?
Offline monzablue16v
Re: 1.8T Error codes
« Reply #1 on: 28 February 2006, 21:58 »
Just a guess, but I would say Boost Pressure Control Valve (N249) :)
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #2 on: 28 February 2006, 22:05 »
Faulty MAF could be the cause too :undecided:
Say bye bye
« Reply #3 on: 01 March 2006, 09:24 »
Yeh thanks for that monzablue... would never of guessed!!! was kinda hoping on bit more technical advice then that but thanks just the same :wink:
If the MAF sensor is what i think it is, ive been at it already gaz, bought one didnt make a difference!
Its the thing with two screws on the air box pipe right?! :embarassed:
Say bye bye
« Reply #4 on: 06 March 2006, 17:22 »
Still having the same problems  :sad: Worrying thing is one day the engine light is on then its off for a day then its on  :sad: :undecided:
anyone got any ideas?
Offline BenjiC
« Reply #5 on: 09 March 2006, 16:32 »
Sounds like my problem mate - I've been told it's a faulty air intake pipe. My engine management light comes on and off.
Does the power come and go on yours?
Say bye bye
« Reply #6 on: 09 March 2006, 19:08 »
Yeh, i think it does a BIT  :undecided: people jus say its me bein paranoid lol happened just after i got the cam belt and that changed. im trying to get my mate to look at it on the weekend, he's more into his turbos then i am
Offline BenjiC
« Reply #7 on: 09 March 2006, 21:41 »
Lemme know what he says would ya? I've been quoted hundreds by VW to fix it. I've been discussing it on the threads but I think I'm gonna use it as an opportunity to tune mine up a bit.
God bless credit cards!
Say bye bye
« Reply #8 on: 10 March 2006, 12:38 »
I seen your other post re turbo intake pipe fault? thought mine had the same problem, but topher put me in the right direction. Have you run diagnostic on yours?
Offline BenjiC
« Reply #9 on: 10 March 2006, 16:42 »
Yes at VW so I know that's what the problem is. Just need to decide which is the best part to replace it with, and what else to add at the same time!
