Author Topic: Brake discs + Brake Pads  (Read 2184 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 27 February 2006, 17:01 »
bad news need to replace the brake discs and pads
 any suggestions as to which to get wudnt mind the sporty ones with the holes in them
as logn as there not too costy and as long as they dont make too much noise
any suggestions pls post
thanks
<<<Big Build Thread>>>
kompliance
Re: Brake discs + Brake Pads
« Reply #1 on: 27 February 2006, 17:21 »
When I had to replace the balipers on my MR2 I used these people; http://www.brakesint.co.uk/
I found them excellant for factory replacements and very cheap. I'm not sure if they do vented/grooved style black diamond stuff but its a start if you decide to replace them straight out.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 27 February 2006, 23:19 »
Only worth uprating fronts, IMO, no need for rears.
Have a look here..... www.buypartsbuy.co.uk
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline D4veo MK4
« Reply #3 on: 03 March 2006, 15:09 »
Mine need replacing soon and i have been looking around for some uprated ones for my 2.0 GTI, 2003.
I've looked at the Black Diamond Combi Discs which are Drilled and Grooved and the Black Diamond Fast Road Predator Pads.
I found them on: www.europerformance.co.uk
« Reply #4 on: 03 March 2006, 18:56 »
Best pads I've used by miles, (for track days & road), are the Ferodo DS2500's. Unbelievable bite..... They even worked well from cold (even better than standard pads). Sit down for the price! :grin:
If you don't want some as hardcore as that, then try the DS2000's (just called DS's now, IIRC).
Alot of people on the GTi-6 forum (who do lots of track days) have been a bit disapointed with that Black Diamond set-up (& also EBC stuff).
Also bare in mind, that drilled/grooved discs will wear your pads out quicker than solid discs.
Offline richy
  • neeeeeeeowm
« Reply #5 on: 04 March 2006, 19:20 »
I got some Brembo grooved discs a while back from German Swedish.  Also got some ebc "green stuff"pads from there too - quick delivery and not a bad price either.
I'm pretty pleased with this set-up.
54-plate Golf 2.0 FSI GT.  Leather interior.
Offline kniterider
  • had most, sold most and often buy more!
« Reply #6 on: 04 March 2006, 20:26 »
if your on a budget try stuart tunstall (euro parts leeds branch in the deals/discounts section) you get discount for being a golfgti.co.uk member and there prices on standard stuff are good, they also do some grooved discs at a very good price!
have a nosey!!
 :grin:
Offline doross
« Reply #7 on: 04 March 2006, 21:25 »
Put standard pads and discs on all round last year for under £200 for the lot from German and Swedish and fitted it all myself. Brakes are very good, good enough to get the ABS working on any road surface and have never had brake fade. Drilled/slotted discs cause noise and more pad wear than standard discs. Drilled/slotted discs look better but have no performance gains over standard discs/pads on the road.
I think it all depends on how deep your willing to dig into your pocket for your new brakes.
Happy hunting! :smiley:
