Author Topic: 16v 1.8 lack of top end power  (Read 1830 times)
Offline oak green_dub
« on: 26 February 2006, 19:19 »
I've got an '89 1.8 16v which is standard and has 100k on the clock. It
burns nor loses any oil. It has just had its vavles re-ground and the valve
stem oil seals done by VW.
It has loads of low end torque and is very lively low down the rev range,
my problem seems to be higher up the rev range where it seems to be
holding back. I had a 16v a few years ago and it seemed to be the other
way around, it would start to rev slowly and as the revs climed it would
feel as though it was revving easier. This one seems as though it's run out
of steam by 4.5-5k rpm. It will rev right round to 7k without complaint,
no pinking etc. but it just doesn't produce the rush my old one used to
and just seems to make more noise than go
Any ideas would be greatly appreciated
John
Offline takethefifth
Re: 16v 1.8 lack of top end power
« Reply #1 on: 26 February 2006, 21:14 »
Probably worth getting the timing checked, according to the 16v guys on here 4200 is where it should start taking off!!
Offline Devon Joe
  • Liebe zum ropey Automobil
« Reply #2 on: 26 February 2006, 21:50 »
It sounds like its otherwise running fine so definitely check the timing- my '89 16v was one belt notch out for ages after I did the stem seals...its quite easy to get it wrong even for a pro (and i'm not :smiley:)
If only my Volkswagen was as reliable as everyone else's...
« Reply #3 on: 27 February 2006, 20:11 »
Thanks guys, I'll get it in to have it checked.
Offline Rainey
« Reply #4 on: 05 July 2006, 12:17 »
What happened with this and is it the ignition timing you check or the cam timing you check?
Checkout my MKII
Judderi
« Reply #5 on: 07 July 2006, 10:25 »
Bump! Reply Dude what was the problem?
VeeDubGTI16v
« Reply #6 on: 07 July 2006, 10:38 »
sounds like cam timing to me :huh:
Offline Rainey
« Reply #7 on: 11 July 2006, 10:26 »
yeah got mine booked in a local vw garage is doing the cam and ignition timing, cleaning out the inlet, and checking everything including the co2 for me at a price of £35 good price i think what ya reckon
Checkout my MKII
Judderi
« Reply #8 on: 11 July 2006, 10:28 »
Very good price! Were you suffering from the same problem?
Offline Rainey
« Reply #9 on: 11 July 2006, 10:33 »
Yeah seems bogged down as if it is overfueling still goes but not as fast, when i start it cold it splutters a bit and also seems to occasionally pop like a small backfire
Checkout my MKII
