Author Topic: Mk2 to Mk3 Dash Conversion Help....  (Read 5163 times)
Offline JettaHaywood
  • I Own a Boot.
« on: 21 February 2006, 22:49 »
Hi there.... i own and mk2 and i am wanting to put a mk3 dash into my mk.... what i'd like to know is if i'll need the wiring loom too or if my mk2 loom will be fine.
what i mainly need to know is how th Mk3 dash/dials are driven. Are they fed from the ECU or direct from the engine/gearbox/misc sensors ?
i own a jetta but seeing as they are basically the same as golfs i thought you guys might be able to help.
Offline ...joe
Re: Mk2 to Mk3 Dash Conversion Help....
« Reply #1 on: 21 February 2006, 22:53 »
you will probably get help from a guy on here called dizzie, as he has done this conversion.
i think if you have a late spec jetta (with the hazard light on the steering column) then i think you just use the mk3 loom and plug it into the fuse box. if its earlier spec i think its a bit harder as you have to change to a late spec fuse box.  either way i think you do need the loom.
thats all i can tell you but like i say, dizzie will know and you might want to take a look in the projects section for how he did his...... :)
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
  • I Own a Boot.
« Reply #2 on: 21 February 2006, 22:59 »
thank yuou very much for your help :)
mine is the earlier spec :( F reg.
Offline ...joe
« Reply #3 on: 21 February 2006, 23:02 »
yeah mines 90 spec but has an early loom :( i was tempted with a corrado dash conversion...... still might if i get the bottle to pull mine out!
Offline Ozz
« Reply #4 on: 21 February 2006, 23:06 »
I was considering the corrado dash swap too, but have picked up a mk3 dash for free so want to do that when I pluck up the courage!! Mines an early gti so will have the same problems!
Mk2 Gti 8v
Offline omg its aj
  • UNF UNF UNF UNF POP!
« Reply #5 on: 22 February 2006, 01:07 »
What sort of dash swaps are possible with a mk1?
When i get the cash together for mine i was thinking of completely upgrading interior, including a less-boxy dash. Always fancied the idea of a custom one (GRP backbone then trimmed to match the rest of the interior).
Ambitious project for me to be taking on i know  :laugh: but i plan to do it over a year or so.. :)
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 22 February 2006, 12:29 »
Putting a mk3 dash into a mk2 is fairly straight forward, but very time consuming. I did mine in about a week's actual work - but draged over about 6 weeks. (it was xmas and cold outside!)
What you will need:
The whole dash from the mk3. I advise removing it yourself from a scrapper as you'll get an idea where various parts go and how they go back together.
All the switches... tip, to remove the headlight switch first remove the small cover to the right of it. put your finger behind it and you'll feel a small catch. push that in and the switch will come out.
All the loom's for the switches, heaters, everything!. You'll be cutting the plugs off and solding them onto your mk2's loom. Don't worry, all the colours are the same (god bless VW there!)
The huge metal support bar - The whole dash bolts to this!
The heater matrix and fan, etc. Easier to change the lot.
All the heater controls.
The stalks - may aswell while you're there...
Bascially everything in the dash area of the mk3. I bought the lot for £40.
Start by removing the entire mk2 dash. the mk2's steering wheel support is done with sheer-off bolts. you'll need to remove these and replace with 10mm bolts. You'll also need to drop down the steering wheel. the mk3 has height adjustable steering. If you're planning on using this you'll be bolting the support directly to the support bar. If this is the case make sure whoever welds the support bar in does a A+ job as when you get out of the car most of us pull our weight up using the steering wheel. You don't want the whole dash falling onto your lap! With alll the little bits of dash removed like the switches and clocks, centre console, etc the mk2 dash unbolts with 1 on each end which you can see. 2 under the rain tray (you won't be able to see those, just feel for them) and 4 which bolts 2 support peices to the bulkhead in the middle of the dash. It'll pretty much drop out then.
This is the first time you get to hold the mk3 dash in the car and see just how much you have to cut off the sides to get it to slide into the car. About 3/4" off each side (ish). with the help of a friend you'll need the dash held where it's going to go. then mark on the corners where the first cuts will be made. Once you've done this a few times the dash will start to sink closer to the windscreen. You'll soon find out that the underside of the dash is hitting the bulkhead...
You now have 2 options:
1) Cut away the bulkhead so all the heater vents remain intact. This would be the best option, but it compremises the car's stucture. If you want to weld in a strut brace close to the bulkhead then this option would be good. As I can't weld I went for option...
2) Cut away all the heater pipes to work around the bulkhead. This will then require some fibreglassing to get them back together. I currently haven't done the fibreglassing part as I want to sink my dash in a little further first. This requires cutting out my support bar and rewelding it in closer.
Anyway, back to the cutting. Once you've cut a fair wedge off the side corners the vertical peices that touch the door rubbers will be very close. You'll need to trim down there then. You'll also need to start reshaping the curve of the dash where it meets the windscreen. this is best done with the windscreen removed. Once you get the dash this close into the car there should be no gaps anywhere (unlike mine). You will have cut away most of the heater vents underneath now, this will require some thought into how you're going to reconstuct it later once the dash is in there perfectly. Using parts of the mk2 heater setup will help here.
Before you weld in the support bar you'll need to decide about your steering wheel. If you're not having it height adjustable then bolt it back in where it was with the mk2 dash maintaining the original position. You may need to drop it slightly to clear the bottom of the dash. Mine is dropped about 10mm I think. I'll raise it when I redo the dash.
Once you've done all the cutting and got the dash in there perfect it's time to get someone to weld the support bar into the car. In the mk3 it's bolted in. You'll need to cut off the mounting points where the bolts would go and weld it in. There is a small support piece in the middle you can also weld in too but personally I didn't feel the need as mine is solid anyway.
Mk4 Golf 150PD
Offline Dizzie
« Reply #7 on: 22 February 2006, 12:30 »
heater vents. The connecting pipe that goes from the matrix to the screen blowers works well there and goes around the bulkhead perfectly. Oh, I almost forgot about the matrix and fan blower. These almost bolt straight in. you'll need to drill another hole through into the engine bay to get the matrix in, but the fan hole lines up nicely. Make sure when you mount the fan section it lines up nicely with the hole above. A ring of foam helps here and seal it off to avoid a cold draft when driving. On the bottom of the matrix there are 2 vents which I didn't use. I simplely plastic welded a piece of plastic over them which sealed them off nicely. Took me a while to work out why the chocolate I put in my centre console was always melted! The pipe that goes behind the glovebox hasn't been modified on mine. might have to when I sink the dash in further. The one on the driver's side had to be cut in half so when it's sunk in further I may have to take a different approach to that one.
Switches... Easy enough. All the wires are the same colours on the mk2 as the mk3. Just chop off and solder on. The only bits to watch out for is the fog light is part of the headlight switch on the mk3. When you join the 2 run a new earth else the right hand side lights are dimmer than the left becuase of the foglight using the same earth wire. If you have electric windows you'll need to decide where to mount the switches. mine are on the floor of the centre console and stop things flying out of there during hard accelerating. On my car which is a '87 mk2 the new stalk hazard switch only works when the igition is on. The original mk2 switch which is tucked up in the dash still works perfectly. this might be different on your's?
That's pretty much it. It's not hard. Just take your time and do your cutting right. I'm not happy with my dash and I do plan to rip it out and start again so it looks perfect. One day...
Mk4 Golf 150PD
Offline HARDCOR3
« Reply #8 on: 22 February 2006, 12:50 »
if anybofy wants 1 to chop up to practice, i've got a mint black dash parceled up ready to go, that some flee-bay clown p!ssed me about with, you can have it for the price of the postage, probably about a tenner or so, think it's got pretty much all the switches and vents with it too from what i can remeber....
  • I Own a Boot.
« Reply #9 on: 22 February 2006, 14:07 »
thanks so much for this dizzie :D much appreciated.
i'd be VERY interested in this dude..... where are you based?
