Golf mk3
hardmonkeys
Rear Window Problem
Topic: Rear Window Problem (Read 1490 times)
marcusps
Rear Window Problem
21 February 2006, 10:16 »
I have a Golf GTI Mk3 howver i have a problem with both my rear windows. The windows will go down but not go up. Also the windows will not lock meaning you can pull down the window with your hands. What could the problem be, is it common for golfs?
adyh
Re: Rear Window Problem
21 February 2006, 11:12 »
It means that the mechanism is broken . I had one go on my car. You can fix it by taking the mechanism out of the door [tape up the window first to stop it dropping] and re-securing the metal bead on the wire into the plastic holder. [its a bit fiddly] . I used a couple of cable ties .
marcusps
21 February 2006, 18:09 »
is there anywhere where i can get instructions how to do this, i do not want to pay £150 per panle that vw quoted me
adyh
22 February 2006, 09:27 »
Its all fairly obvious when you get the door car off . Go and buy a haynes manual is you are apprehensive .
mysticblue_mk3
27 February 2006, 17:06 »
You don't mention whether you have electric rear windows
, but seing as it's a GTi, it's more than likely.
Check out this link, I hope it's of some use to you
http://www.golfgtiforum.co.uk/index.php?topic=24454.0
Golf mk3
hardmonkeys
Rear Window Problem
