Author Topic: Sloooow wipers?!?!  (Read 11319 times)
Offline welshgar
Sloooow wipers?!?!
« on: 20 February 2006, 19:40 »
is there an upgrade to the very sllllllloooooooow wiper motor for the mk1??
just found this on flea-bay... would it work or is there an easier way???
cheers :smiley:
http://cgi.ebay.co.uk/VW-GOLF-GTi-MK1-front-wiper-motor-upgrade_W0QQitemZ4612622221QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mk4 GT TDi::RS4's::weitec coilies::RCCR::polo mirrors::cream leather::
MK1 1.5 GL Auto restoration....coming along slowly :-(
its not the winning that gives me pleasure....its the taking apart
Offline Phil303
Re: Sloooow wipers?!?!
« Reply #1 on: 20 February 2006, 22:55 »
Hi,
You say the wipers are slow, but is that slow compared to newer cars, or slow compared to another Mk1? If the former, then welcome to the world of the 20 year old Mk1 – be prepared for things like that! If the latter then it may be because of the following:
First of all, are you sure the wiper motor and mechanism are running smoothly and freely?
You may have a sticking wiper mechanism and/or slightly seized blade mountings with a perfectly fine motor or conversely a knackered motor with a perfectly good mechanism. Loosen the wiper arm mountings just below the windscreen and check for rust. Fling a load of WD40 around and see if that makes a difference. Also try a lubricate the wiper arm mechanism in the scuttle area under the bonnet. Lastly, replace the motor. These aren't too expensive from breakers yards and you shouldn;t have any trouble finding one. I think Mk2 Golfs use the same motor but double check that first.
I only say ll this because my wipers were moving with the speed of a glacier and I bought a secondhand motor and arm mechanism only to find out that the original motor was fine, I just needed to lubricate the blade mountings as they had rusted slightly. Once done they run perfectly.
Good luck.
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #2 on: 21 February 2006, 11:55 »
cheers :smiley:
I think this is off a cab, i put one on my last mk1 but it was no faster than the original  :undecided: I heard something about changing the relay as well which is supposed to help but i never found out which one to use - In the end, considering how much mk1's slide around in the wet, i decided i was probably better off slowing down a bit :laugh:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
« Reply #3 on: 21 February 2006, 17:10 »
You can fit a MK2 motor to the MK1 linkage, but you'll need to splice on the MK2 plug to your loom as well.  Not a big deal as I think all the wire colours match up :)
« Reply #4 on: 21 February 2006, 17:14 »
I always thought the mk1's problem was due to a lack of power from the fuse box  :undecided:
my dub project:-
« Reply #5 on: 21 February 2006, 17:18 »
If so then swapping the relay may help, its the one with '19' stamped on it.  Replace it with one stamped '99' from a MK3 Golf or Passat to get the nifty variable intermittant wiper function  :cool:
Offline welshgar
« Reply #6 on: 21 February 2006, 19:30 »
shouldnt be too much of a problem....(im a sparky...but car electrics are very different :undecided:)......but the wipers move v.v.slowly.
i thought it was just the linkage (ihad a mk2 yrs ago, and the same thing happened) and greased all that but its still soooooooo slow, therefore i thought it was the motor.
good to hear i can put a mk2 one in if i want, but how does a "99" relay give you intermittent wipe if there isnt that option on the stalk????
if its just a lack of power from the fuse box, how have others up'ed it??? :huh:
phil, the wiper really is that slow!  :smiley: in fact if it was raining out, then id be in 2 minds wether or not to take the ol'gal out in it  (fair weather car already.. and ive only had it 3 days .. LOL :grin: :grin:)
sorry for all the q's but it really is that bad!!
i thought id ask some questions  first b4 i waded into the "brand new" area
 :undecided:
« Reply #7 on: 22 February 2006, 08:32 »
Its an ingenious little device, nothing apart from the relay is needed.  All you do, is click the stalk down and up again, then wait for the required delay and click the stalk down again :)
I'd defo go with a newer wiper motor first :)
Offline welshgar
« Reply #8 on: 22 February 2006, 10:03 »
yeah, thats what i thought..... might aswel get it right first off......
so, im off a shopping :smiley: a new wiper motor and a 99 relay it is :smiley:
« Reply #9 on: 22 February 2006, 10:25 »
The rear wiper motor is also the same on a MK2, so if the back one is getting a bit tired you know what to do ;)
Also you can use a MK2/MK3 intermitant relay to give your rear wiprer an intermittant setting, its number '72' but am unsure what number the non-intermittant MK1 relay is.
But it's probably not worth it, my intermittant rear wiper annoys me, I always switch it on then off again!
