Author Topic: Hazard lighs not working  (Read 6441 times)
Offline GemGTI
  • Gemma
« on: 19 February 2006, 18:32 »
I was told it was the switch that was faulty so I bought a new one off ebay and this doesn't work either. Does anyone know why this could be? The indicators are working fine but nothing happens when I turn the hazards on except a green light comes on on the dash. And I've done something really stupid... whilst trying to sort the hazard switch out I tried to put a dash blank in below where the hazard light goes and accidentaly dropped it and it fell through the hole and had gone behind the dash! Typical me! What a numpty! Anyone have any ideas how to get it back out as otherwise that will be another rattle that drives me crazy!
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Hazard lighs not working
« Reply #1 on: 19 February 2006, 20:02 »
Regarding the Hazards lights - check the fuse/reply is not the issue - full details of fuse/rely setup on mk1's are shown on this website
http://dana.ucc.nau.edu/~kaw5/electrical.htm
Regarding the  blank cover - take the stereo out and you should be able to get your hand behind the dash to get the item out...
Hope this helps.
« Last Edit: 19 February 2006, 20:06 by Madone »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #2 on: 21 February 2006, 12:08 »
 :nerd: Sounds like its probably the relay, if the green light comes on & the indicators work then the circuit should be ok - if you know someone else with a mk1 you could try their relay before buying a new one.
Its unlikely that blanking plate will stay behind the dash for very long, theres nothing behind there to hold it - i wouldn't recommend sticking your hand behind there as you could end pulling wires off plugs etc...  you'll find it on your carpet one day when cleaning and wonder what it is and where it came from  :laugh:
You dont seem to be having much luck at the moment  :sad: how did you get on with the rust problem  :huh:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline alpesh
« Reply #3 on: 21 February 2006, 12:33 »
Your cicuit is fine. I think your hazard relay is "sticking". Relays can often stick. Give the fuse box/relays a tap and it might start working.
With the balnking plate - remove the stereo, this will give you more access to see where its gone.
Offline GemGTI
  • Gemma
« Reply #4 on: 21 February 2006, 20:32 »
What rust problem? Do you mean my knackered chassis? I've had the welding done and the nearside sill is now solid. I'm gonna get the offside done too though just so its solid on both sides. No I really am not having much luck at the moment! I keep annoying certain people (car mechanics and auto electricians) because I dont know how to sort anything out for myself! :cry: :embarassed: And then when I do try ie- the hazard light switch it all goes wrong and I drop stuff behind the f**king dash!!! Oh well at least I'm never bored! :smiley:
« Reply #5 on: 22 February 2006, 09:02 »
Have a word with Tucker, he had exactly the same issue with his hazard lights, turned out to be a mixture of blown fuses and dodgy connections :)
Offline Alps
« Reply #6 on: 16 June 2006, 09:06 »
got the same problem on a Mk1 cab, replaced the fuse box with a diff set of releys, and still no good, i`ll check the releys out again over the weekend.
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline Alps
Re: Hazard lights not working
« Reply #7 on: 19 September 2006, 11:05 »
did you get this sorted?
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
Offline GemGTI
  • Gemma
« Reply #8 on: 19 September 2006, 22:55 »
yes i did in the end thanks  :smiley:
Offline Alps
« Reply #9 on: 01 October 2006, 10:19 »
i had a good look at mine last weekend, ended up replacing 2 fuses #4 and #19, sorted, all working too. what was the prob on yours gem? helps noting it here in case anyone else has the same prob!  :laugh:
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
