Author Topic: Electric Window - Is it on its way out?  (Read 2502 times)
Offline Pimpster
« on: 19 November 2003, 11:40 »
My automatic electric window up movement is having a permanent paddy. It goes up but then half way up it changes it mind and goes back down. I can hold the switch and it will go to the top no problems.
I've heard the electric windows are notoriously prone to not working, but does it sound like mine is on its way out?
Also how much to get new motor etc? ???
Offline Overseer
Re:Electric Window - Is it on its way out?
« Reply #1 on: 19 November 2003, 11:54 »
one thing, sounds silly i know... but is the window clean? because sometimes dirty windows cause them to stick.
i have also heard of some problems tho..
Offline Fraiser
« Reply #2 on: 20 November 2003, 12:16 »
i had the saem problem on my vr6 was a loose connnection on the wiring to the switch/relay- get it checked out only cost you around 20 quid. well worth doing mate.
Offline lloyd_mckee
« Reply #3 on: 09 January 2004, 23:48 »
check the window runners as all vw electric windows are fitted with anti trap if the glass hits a obstacle the window opens again.
Offline nfarina
« Reply #4 on: 21 January 2004, 02:03 »
Had the same problem with mine.
Turned out to be a frayed cable.  Fortunately, the cable/guide assembly can be replaced separately from the motor.  About ?50 from VW.
Nick,
Offline Golfer
« Reply #5 on: 23 January 2004, 08:52 »
Mine does this too, but it's just the rubber seals causing too much friction.  I know this is the cause as it only happenes when the window is dry.  If it is wet, no probs!
1998 Mk3 GTi 8v - now sold :(
2003 BMW 320d 150bhp now bought :)
2002 Seat Leon (almost a Mk4!)
Offline jasonpi
« Reply #6 on: 23 January 2004, 09:01 »
mine did the same granted at the time it was a mk4 but turned out to be plastic clips?! dont know if this relates to the mk3 but worth asking
