Author Topic: Optimax for my 8V?  (Read 8292 times)
Offline Pimpster
Optimax for my 8V?
« on: 19 November 2003, 11:37 »
I've just moved near to a Shell garage and am thinking seriously of using Shell Optimax.
I've been told there is a knock sensor that automatically calibrates the engine to be able to use 98 RON but:
1. Is it ok to do? ???
2. Has anyone used it on an 8V and has it made any difference? ???
3. Is it worth it? ???
Offline Overseer
Re:Optimax for my 8V?
« Reply #1 on: 19 November 2003, 11:56 »
1. it should be ok,
2. i tried it in my old 8v polo.. it was definitely a bit more nippy
3. its best to try for yourself. put some in when you're as empty as poss.. i hear its good to run a few loads through to ensure you're fully maxed up.. not sure how true that is.
« Last Edit: 19 November 2003, 11:56 by Overseer »
golfvr6
« Reply #2 on: 19 November 2003, 13:37 »
Optimax will be fine, the engine should run a bit better. The knock sensor is on the engine so you can use normal unleaded without pinking under load.
Offline Pimpster
« Reply #3 on: 19 November 2003, 13:48 »
Cheers Overseer and VR6 - i'll give it a go and post an update. Gimme anohter 100 miles and the present tank should be empty... ;)
« Last Edit: 19 November 2003, 13:48 by Pimpster »
golfvr6
« Reply #4 on: 19 November 2003, 13:50 »
VW state in the owners manual that using 98RON gives me more torque on my vr6, don't know if it will do anything for the 8v. I doubt it  :-*
Offline Pimpster
« Reply #5 on: 19 November 2003, 14:41 »
I didnt see anything, but the big 95 RON ONLY sticker on the fuel cap made me think...
« Last Edit: 19 November 2003, 14:42 by Pimpster »
golfvr6
« Reply #6 on: 19 November 2003, 16:37 »
Probably means don't use less than 95RON.
Offline Pimpster
« Reply #7 on: 19 November 2003, 17:28 »
I would have agreed, but the ONLY part of 95 RON Only got me a bit perplexed.
I'll give it a go. If its doesnt do anything for mine i'll go back to 95.
What do you run yours on VR6?
golfvr6
« Reply #8 on: 19 November 2003, 17:32 »
I normally just put unleaded in, but if i'm in a garage that does optimax, i will use that. High octane fuel won't damage the engine, only fuel which doesn't have a high enough octane rating.
Offline Glen
« Reply #9 on: 19 November 2003, 22:52 »
Optimax is ok in the 8 valve, as you stated the sticker only means the minimum of 95ron to be used.
Optimax definately works in an 8 valve, works in mine, it does exactly what it says in the ads, makes your engine more responsive, gives it more ooomph!
