Author Topic: all gti,s have a secret digital revcounter  (Read 5872 times)
Offline black_vr6
« on: 20 April 2003, 03:02 »
did u know that if u hold ure MFA to position 2 reset and hold whilst turning off and on the ignition and starting the car the digital display becomes a revcounter
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Judderi
Re: all gti,s have a secret digital revcounter
« Reply #1 on: 22 April 2003, 18:13 »
no i didnt but can you elaborate a bit? Whats position 2. Slider bit or the button on the end?
judderi
« Reply #2 on: 23 April 2003, 16:26 »
I tried it last night and laughed all the way down the road to 7000 revs! :o
Offline davebatt69
« Reply #3 on: 25 April 2003, 20:21 »
cant seem to get that one to work on my 86 gti??? ???
Offline stoat
« Reply #4 on: 28 April 2003, 17:44 »
doesnt work on mk3's though
MK3 GTI 8V
Offline GTI16vGaz
  • New car will be displayed soon.
« Reply #5 on: 29 April 2003, 22:39 »
I cant get it to work on a 1989 GOLT GTI 8v
Offline JayGTi
« Reply #6 on: 01 May 2003, 00:45 »
I tried it today on my 1994 GTi 8v.
The MFA just went mad!!!! :o
The funny thing was that once in this weird mode, when set to 'mpg' it showed 0.2 when idling. Then when i drive it shoots upto 99.9, and then all over the shop..??
The other thing I found was that you could only flick through the mpg, Oil Temp and outside temp status.
So, No it didnt work, 'mpg' just showed lots of useless numbers. Once the car was switched off and back again, all went back to normal  ;D
Offline 16veod
« Reply #7 on: 06 May 2003, 19:42 »
hi  8)
i tried that at the weekend there very good. there was about a 2 sec delay with the rev counter and the digital display. but its still good. once the car is switched off it goes back to normal.
89 mk2 16v
first_timer
« Reply #8 on: 06 May 2003, 23:57 »
cant get it to work on my golf 89 GTi8v
do u leave it on the clock? then stop and start the car?
judderi
« Reply #9 on: 07 May 2003, 11:57 »
You start the car. move the switch to number 2 then hold the button on the end in while turning the car off then back on again still holding the button in. once the car is restarted release the button and then press it a couple of times till the digital rev counter kicks in.
