Golf mk2
90 8v GTI Losing Performance"HELP"
Topic: 90 8v GTI Losing Performance"HELP" (Read 2738 times)
True Blue GTI
1965 1500S Notchback & a 90 5 door MK2 GTI
17 November 2003, 22:31 »
I've got a 90 8v GTI That will run OK for days and then all of a sudden goes really flat(Loses performance)
an injection specialist took a look but couldn't really help appart from getting it running better when it's Behaving.
golfvr6
Guest
Re:90 8v GTI Losing Performance"HELP"
17 November 2003, 22:37 »
Any other symptoms?
True Blue GTI
17 November 2003, 22:47 »
When runnung in slow traffic the engine sometimes surges a little.(The tick over is a little random too).
The guy who tuned and checked it said he had to adjust the timing but i was told the timing is controlled by the ecu.
Last Edit: 17 November 2003, 22:55 by True Blue GTI
golfvr6
Guest
17 November 2003, 23:17 »
Look at the usual suspects ie. air flow meter and oyxgen sensor(if fitted). You are correct about the ignition timing, it is a controlled by the ecu , so is non-adjustable.
mk1
2ltr16v turbo (now with programmable EFI)
17 November 2003, 23:23 »
Check the pleated rubber hose from the air flow meter to the throttle body for splits. Base timing is adjustable on this system, 6 degrees i think
http://www.geocities.com/mk1turbo16v/golf_turbo.html
golfvr6
Guest
17 November 2003, 23:30 »
I think mixture and idle was also adjustable on the early digifant.
Slim Shady
Here all the time
Thrash her like a ginger step child
Reply #6 on:
17 November 2003, 23:38 »
try drilling the airbox
golfvr6
Guest
Reply #7 on:
17 November 2003, 23:45 »
Yeah mate, talk sense when you know some
Tornado-red_gti
GTI forum regular
Reply #8 on:
18 November 2003, 12:51 »
Could it be the knock sensor?
golfvr6
Guest
Reply #9 on:
18 November 2003, 15:48 »
Could be, likely to either a vacuum leak or a faulty sensor.
Golf mk2
