Golf mk1
door height adjustment '82 cab???
Topic: door height adjustment '82 cab??? (Read 2005 times)
miguel
17 November 2003, 16:38 »
how do I adjust the door height on my cab? the bottom of the door is scraping on the top of the sill!!
richandhazel
Global Moderator
Forum addict
Re:door height adjustment '82 cab???
17 November 2003, 16:51 »
Have your door hinge pins worn?
miguel
18 November 2003, 09:26 »
no, not much but the door looks to have been repaired in the past and this maybe my problem! the hinges appear to have little vertical adjustment so I was going to either:-
A) drill out the bolt holes a bit bigger.
B) helicoil the threaded plate and use a smaller bolt
C) put another door on.
I can get another door but its white instead of bronze(brown?) how much does spraying cost these days?
mk1mat
MK1 1800 Gti
21 November 2003, 17:53 »
If the door can be lifted back into its original position then i would advise you to get new hinges and hinge pins, wont cost much and are a dealer part, cost me less than a tenner to sort, its gotta be worth it!!! good luck!
Golf mk1
