Author Topic: throttle response  (Read 1431 times)
Offline Gav1n
throttle response
« on: 10 February 2006, 20:05 »
Hi all
thank you for letting my post on this board.
....I have a 2000 (w) Golf GTI 2.0 ..90000 miles .. lm getting very slow throttle return(when l take my foot off the accelerator the revs hold and then return slow)..   I have looked in the throttle body and the butterfly (what ever you call it) seem to return ok and the cable seems ok..some times it gets so bad l can only do slow gear changes because if l change fast it sounds like lm slipping the clutch.....please help me ...
thanx gavin
Offline richandhazel
Re: throttle response
« Reply #1 on: 11 February 2006, 13:13 »
Hi all
thanx gavin
Surely it has an electronic throttle box :huh: Or do some of the mk4's still have cables :undecided:
Offline Gav1n
« Reply #2 on: 11 February 2006, 13:58 »
hi
No its deffently got a throttle (accelerator) cable...
« Reply #3 on: 11 February 2006, 14:39 »
Ah yes, just had a look in the Haynes manual and I see that some do still have the cable.
If the throttle body and cable and routing is good, can only be at the pedal itself. Is there a return spring that has come off maybe?
