Author Topic: folding front seat tilt cable  (Read 2078 times)
Offline gti jim
  • return of the vac...
« on: 10 February 2006, 14:31 »
ok another little job to sort out.  the cable in the seat snapped yonks ago and i'm getting a bad back having to lean down to move the catch by hand  :laugh:
saw this on flea bay
http://cgi.ebay.co.uk/VW-GOLF-MK2-MK3-INNER-SEAT-TILT-CABLE-GTI-16V-VR6_W0QQitemZ4612210508QQcategoryZ9889QQrdZ1QQcmdZViewItem
this is what i need but how the hell do i replace it??  :undecided:
pointers/ suggestions as always enormemente apreciado  :smiley:
Offline Haribo!
Re: folding front seat tilt cable
« Reply #1 on: 12 February 2006, 03:10 »
you need to take your seat out, then speperate the top of the esat from the bottom, i cant remember how that works but its obvious whe you look at it, then take the seat cover off , its cliped on with variour metal staple things, then it should pull up all the way to the head rest then youll be able to see exactly how the wire is set up and attached, just remove and replace i think, i dont know if theres an easier way....hope that gets you somewhere
