Author Topic: reving out at 5000 rpm, CAN ANYONE HELP.  (Read 1562 times)
Offline Gavin2006
« on: 07 February 2006, 23:11 »
I have a GTI Golf MK3 that keeps on reving out at 5000 rpm, CAN ANYONE HELP.
Offline adyh
Re: reving out at 5000 rpm, CAN ANYONE HELP.
« Reply #1 on: 08 February 2006, 09:51 »
I believe that this has something to do with the hall sensor.
Offline Bazzer
« Reply #2 on: 08 February 2006, 09:58 »
do a search - loads of people on here have discussed this before!  :wink:
Bazzer
Offline Gavin2006
« Reply #3 on: 08 February 2006, 19:10 »
What is a hall sensor????? I have tried searching the forum for HELp but there is not information on Reving out. The car does not stall it just hits the rev limiter at 5000 rpms. How can this be fixed.. Any help Please..
Offline adyh
Offline Neaty
« Reply #5 on: 09 February 2006, 10:09 »
I have this problem with mine, it hits the limiter at 5000rpm
i have been told to replace the hall sendor then erase the fault code of the ECU, but i am going to change the Distrubuter which i beleiver the Hall Sender is part of. They arent cheap tho!
Offline GuvGTI
« Reply #6 on: 19 March 2006, 22:46 »
hiya guys did you manage to sort your problem out... cos i got the same thing! let me kno how you guys get along, i gotta do mine aswell. do u rekon its a serious prob?
Thanks
Guv
Offline Neaty
« Reply #7 on: 20 March 2006, 10:16 »
I havnt sorted mine yet, my clutch is going so i think i am going to sort that out first!  :sad:
Offline majic mk3
« Reply #8 on: 20 March 2006, 19:38 »
Check the timing is correct, mine and soooo many other people have had this problem and the timing has turned out to be wrong. Mine was two teeth out, still ran smooth and nmicely, just underpowered and revs cut in at 5000rpm.
Hope this helps
