Author Topic: re-circulating valve.  (Read 1196 times)
Offline sambo
« on: 07 February 2006, 18:43 »
Hi.
On my mk4 1.8T my recirculating valve (dump valve?) makes a bit of a noise, i know it is supposed to, but this is more like a chuffing noise when i change gear, it has been getting more prominent over the last few days and i thought i read on here somewhere that it could be knackered?
Question is, is it worth replacing the standard one with something like a forge. Are these any better in quality, durability and does it really reduce turbo lag as it says on the box?
Also when i floor it, once the turbo has kicked in the acceleration seems to studder a few times momenterally every now and again, not had a turbo car before so noy sure if its normal or not..
Could these be the same problems?
Any info greatfully recieved.
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: re-circulating valve.
« Reply #1 on: 07 February 2006, 19:26 »
the hesitation in acceleration could be because of the faulty diverter valve
the forge dv's use a piston rather than a diaphragm so its more reliable, should last longer. there isnt any real noticable lag with the 1.8T's on stock turbos, i reckon any difference people find in that respect is placebo.
