Author Topic: load sensitive pressure regulator  (Read 1820 times)
Offline mwep201081
« on: 16 November 2003, 23:48 »
i replaced the whole axle on my 1300 with that from a gti. the car failed its mot on the load sensitive pressure regulator. is this easy to set up or can i remopve the unit from the axle to get it through the mot? also any idea if fast road cams are avialable for a 1300?
golfvr6
Re:load sensitive pressure regulator
« Reply #1 on: 17 November 2003, 10:35 »
The 1300 didn't have a load sensitive valve as standard so i don't think you need it for the MOT. The general rule is if its fitted its got to work. Phone a good MOT centre for advice. I wouldn't bother modding a 1300, its not worth it, just enjoy the fuel consumption!
Offline mk1
« Reply #2 on: 17 November 2003, 23:00 »
When you fitted the gti rear axle, did you fit the drum brakes?. If you have the discs on you will need the load compensating valve. Steve.
