Author Topic: Help I think i need a new ignition switch  (Read 2818 times)
Offline tianaroja
« on: 16 November 2003, 17:18 »
I know ive got a problem I think i know the answer, but has it happened to anybody else ?
i am driving along no problem all of a sudden with no warning the car cuts out i get no ignition lights radio goes off headlights go into parking mode as if i have removed key , i pull to the side of road and car restarts straight away this has now happened twice i have changed ignition switches on mk2 with no probs mk3 looks harder Shear bolts involved any help/ advice would be appreciated
golfvr6
Re:Help I think i need a new ignition switch
« Reply #1 on: 16 November 2003, 22:35 »
Might sound like a silly question but have you check the wiring that goes into the ignition switch.
Offline Cupra Turbo
« Reply #2 on: 17 November 2003, 00:32 »
I've just had my ignition switch/barrel etc changed by my local VW garage, they said it was the reason for my bad starting.
They said that 3rd party immobilisers and alarms not fit correctly can knacker the connectors on the back of the switch etc...
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
Offline tianaroja
« Reply #3 on: 17 November 2003, 12:48 »
wiring and connector appear fine not sure how the system works as you dont have to turn key for radio to activate its obviously different to mk 2 and no doubt more expensive
the removal of ignition barrel lock and switch frightens me as there are shear bolts to drill out but does anyone Know if you can remove switch without taking all this off steering column
Offline tianaroja
« Reply #4 on: 17 November 2003, 22:02 »
i have phoned around a few places today and have been told that ignition switches on mk3 are popular faults so i think its favourite how hard is the shear bolt to get out of ignition lock clamp?
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
« Reply #5 on: 05 January 2004, 01:01 »
I just changed the ignition on my mk3. (Burned out the radio turn on trigger).
I took a 'whizzer' and cut a notch on the sheer bolt.  Now its a screw, I can take it off and put it on like any other screw.  You can use a dremmel or rotozip if you got one.  I used an exhaust cutter (It's a pretty big screw and it really isn't on too tight)
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
