Author Topic: Headlights FUBAR - HELP!!!!  (Read 1607 times)
Offline Jaywalker
« on: 05 February 2006, 19:39 »
Please, please, please can someone help me out?!?!?
My headlights have suddenly stopped working completely. I've got Fogs/Sides/Rear/Full Beam etc, but for some reason BOTH dipped headlights have stopped working. I've checked the bulbs - these are fine and everything else electrical seems to work (touch wood). What's the heck's going on?
I'm in dire need of a car next week and if I can't drive it in the dark, I'm stuffed.
Any ideas?
« Last Edit: 05 February 2006, 19:45 by Jaywalker »
Offline GolfGL
Re: Headlights FUBAR - HELP!!!!
« Reply #1 on: 05 February 2006, 19:54 »
could check the fuses, did you try new bulbs even if they didnt look blown.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Jaywalker
« Reply #2 on: 05 February 2006, 20:01 »
I'll go check the fuses now - stupidly I haven't got any bulbs. Would they both go at exactly the same time?
Offline Jaywalker
« Reply #3 on: 05 February 2006, 20:14 »
God I'm pathetic. Can't even get the fusebox cover off to have a look. I've pushed the two buttons in, but don't know which way to pull the cover. It doesn't seem to want to budge and I don't want to break it.
Offline Jaywalker
« Reply #4 on: 05 February 2006, 20:52 »
OK - I've got the fuse box off. They're fine - I've checked them with a meter. Also, I've checked the bulbs - they're fine too.
I had an immobiliser fitted today and I hadn't tested the lights out until tonight. Could they have done something dodgy? Could the headlamp switch be knackered? Where can I get a new one quick?
« Last Edit: 05 February 2006, 21:14 by Jaywalker »
Offline vr4000d
« Reply #5 on: 06 February 2006, 16:44 »
i had similar prob with mine turned out it was just dodgy connections on the back of bulb, all i done was clean conections and wd40 them and they have been ok since.
but it might be worth contacting people who done ur immobiliser and mentioning it:)
Offline Jaywalker
« Reply #6 on: 07 February 2006, 00:09 »
Hello people.
Sorted!!!
Thought I should mention this in case anyone else gets caught out, but apparently this is quite common. To fit the immobiliser the fitters have to fart around with the connections to the fuse box. Anyway, I took it back and they fixed it in half an hour.
Moral: IF YOU GET ANY ELECTRICAL PROBLEMS AFTER HAVING AN IMMOBILISER FITTED - TAKE IT STRAIGHT BACK.
