Author Topic: Ignitions lights  (Read 829 times)
Offline Mk2Kezza
Ignitions lights
« on: 02 February 2006, 09:16 »
Quote
Right, I noticed the other day that when I switch on the ignition the battery light is on constant (thats normal) and the Coolant sensor light flashes - both go off when you start the engine. Now, the oil light comes on too - flashing also, but goes off when you start the engine. I don't ever remember three lights being on with the ignition? Am I going nuts? :laugh: I don't recall three lights with my Jetta either?  :shocked: :undecided:
How many and which are supposed to come on (flashing or not)?
<br />Almost finished.....
Offline takethefifth
Re: Ignitions lights
« Reply #1 on: 02 February 2006, 09:29 »
Thats fine, its just telling you that your oil pressure is low.... kind of obvious cos your engines not on but thanks anyway VW!  At least you know the sensors working  :smiley:
Offline Mk2Kezza
« Reply #2 on: 03 February 2006, 20:05 »
That would make sense I suppose - have a little oil leak from the rocker cover. Its a bit on the wonky side.
