Author Topic: Fitting a replace ment Knock Sensor  (Read 4229 times)
Offline Tornado-red_gti
« on: 14 November 2003, 13:11 »
   My mk2 8v has been playing up. Hesitating, lack of power, but only occasionally. I was kindly told by GolfVR6 that it could be my knock sensor.
  I have checked out a replacement, its about ?35 from hayselden VW. But about ?50 to get it and get them to fit it.
  Is it as simple as swapping it for the old one or should i get them to fit it?
  All views very welcome
  Dave
golfvr6
Re:Fitting a replace ment Knock Sensor
« Reply #1 on: 14 November 2003, 13:40 »
Is it the knock sensor that is at fault? fitting a replacement is quite easy, unplug it from the wiring loom, and unbolt it from the engine. Just make sure when the new one is fitted that you tighten the bolt on the sensor up to the correct torque, or it won't work properly!
Blue MK2
« Reply #2 on: 14 November 2003, 14:02 »
Knock sensor? that the part bolted to the engine on the left of the oil filter?
« Reply #3 on: 14 November 2003, 14:39 »
   I'm certain it is the knock sensor. Reading about other peoples similar problems in forums I think it is probably worth changing.
  One less thing to go wrong in the future!! ;)
golfvr6
« Reply #4 on: 14 November 2003, 15:23 »
Go for it then  ;)
golfvr6
« Reply #5 on: 15 November 2003, 00:39 »
Check the knock sensor already on the engine is not loose.
« Reply #6 on: 17 November 2003, 15:38 »
 I fitted the new Knock Sensor on sunday and it did the job.
  So now i have all the pure power of my 8v beast all the time!!
  Hurray!!!!! ;D :D :) ;) ;D
golfvr6
« Reply #7 on: 17 November 2003, 15:44 »
Nice one  ;D Glad i was right for a change  ;)
« Reply #8 on: 18 November 2003, 12:47 »
 You don't grt a 5 star rating for nothing!!!
golfvr6
« Reply #9 on: 18 November 2003, 15:40 »
cheers  :-*
