Author Topic: Engine Coolant warning light  (Read 2674 times)
Offline JonnoGti
« on: 26 January 2006, 11:52 »
Excuse my igronance. My warning light for engine coolant has been coming on every now and then. Mostly when I first start up and its a cold morning. Me and My dad checked what we thought was it and it seems to be sufficient but we arent the most mechanincally orientated people. Whats this all about guys? thanks
Offline topher
  • Administrator
  • fully functioning
Re: Engine Coolant warning light
« Reply #1 on: 26 January 2006, 12:08 »
happens to me this time of year too, nothing to worry about. i find that dropping a bit extra in the reservoir so that its a bit over the 'max' line helps. something to do with iced condensation in the switch i believe.
Offline JonnoGti
« Reply #2 on: 26 January 2006, 17:18 »
cool ill give it a bash. Thanks  :grin:
kingturbo
« Reply #3 on: 26 January 2006, 18:47 »
i have this problem too on cold days i spoke to a specialist and he said its nothing major
Offline akz786
« Reply #4 on: 27 January 2006, 23:35 »
If this happens more frequently (even when its no so cold) then its your coolant expansion bottle I had the same problem with mine, just replace that coz the sensor is built in ...its about £8 +VAT from VAG and very simple to replace, you may as well add fresh G12 coolant while you are doing this
Hope this helps
Offline JonnoGti
« Reply #5 on: 28 January 2006, 15:57 »
Ive noticed it only happens when its really cold! It never happens when the car warms up but when it warns the driver its got STOP in big red letters then says check engine coolant then service manual..........
Offline kniterider
  • had most, sold most and often buy more!
« Reply #6 on: 28 January 2006, 20:21 »
remove your expansion bottle and shove a pressure washer in it... this normally removes the lime/sh!te so the float can work properly and then youll be fine... common winter prob... but a clean float is a working float... dosnt hurt to get the coolant flushed  once or twice every year... dosnt cost alot but keeps the system clean!!
 :grin:
Offline Scott_1.8T
« Reply #7 on: 25 February 2006, 21:47 »
Just found this post using the search and it's a BIG releif.
I've just bought my first Mk4 GTi 1.8T and this happened the last couple of days and really worried me as there was plenty of coolant in it.
I'm now gonna give it a good clean out tomorrow and that fixes it!!
Offline kniterider
« Reply #8 on: 25 February 2006, 22:04 »
if you can get to the float and clean it , most of the time it will cure things!!
 :wink:
