Author Topic: Sticky Box!!  (Read 1887 times)
Offline Alexg40
Sticky Box!!
« on: 14 November 2003, 10:48 »
The gearbox on my 89 16v is quite sticky to use, 1st gear in particular is quite knotchy and difficult to engage.
Any ideas?!?
Offline Dizzie
  • Make friends with your fast
Re:Sticky Box!!
« Reply #1 on: 14 November 2003, 11:37 »
it's probably the ball that the stick pivots on. U need to remove the gaiter and undo the bolts down there. you'll probably find it's all mashed up from the years of shifting. cheap to replace it'll make shifting a lot better.
There was a step-by-step on how to do it in a recent issue of "the golf" saying how to do it better than I just said.
« Last Edit: 14 November 2003, 11:39 by Dizzie »
Offline Gambit
Re:Sticky Box!!
« Reply #2 on: 14 November 2003, 12:34 »
you'll need to remove the exhaust to gain access to the ball so that it can be changed
something the article in "the golf" forgets to tell you!
golfvr6
Re:Sticky Box!!
« Reply #3 on: 15 November 2003, 00:45 »
Thats correct, as you need to remove the whole mechanism downwards under the car. Thats as i remember it (it was a fews years ago now).
Offline Alexg40
Re:Sticky Box!!
« Reply #4 on: 16 November 2003, 21:31 »
Cheers for that, I'll look into it.
