Author Topic: running temperature  (Read 3553 times)
Offline dubslug
running temperature
« on: 14 November 2003, 06:56 »
guys and gals at wot temp does ur cars run??
mine dont have temp in degrees just the gauge so if u could reply using the gauge as a guide i.e quater half etc etc, cheers. wanna no if im over heating or not
1992 pearl grey 8v
Offline Gambit
Re:running temperature
« Reply #1 on: 14 November 2003, 08:34 »
always sits just a smidge below the half way mark on the gauge
oil temp usually sits between 96-112
Blue MK2
« Reply #2 on: 14 November 2003, 11:38 »
Mine engine temp shows '9' and thats the max ive seen  :-\
Offline Lee
  • Oiiii stop your dog sh!tting on my lawn
« Reply #3 on: 16 November 2003, 09:13 »
The oil temp on my 16v runs between 98-112 and the water temp sits just over halfway then rises in traffic to about 3 1/4s. When the fan kicks in it goes back to halfway.
Ape shall never kill ape
golfvr6
« Reply #4 on: 16 November 2003, 09:55 »
Sounds ok to me, why are you worried about it?
Offline dubslug
« Reply #5 on: 16 November 2003, 10:50 »
temp sits just over half way and my warning light comes on, my old car the temp was just over a quater, just a bit worried thats all
1992 pearl grey 8v
golfvr6
« Reply #6 on: 16 November 2003, 14:50 »
Have you changed your thermostat?
Offline dubslug
« Reply #7 on: 16 November 2003, 17:43 »
yeah its a new car, have changed the thermostat, radator water pump and everything else i can think of, maybe dodgy swith in the dials as if i hit the dash it either comes on if its off or the other way round off if its on??
should i worry??
1992 pearl grey 8v
golfvr6
« Reply #8 on: 16 November 2003, 22:26 »
What car is it?
Offline Mars Attacks
« Reply #9 on: 18 November 2003, 17:26 »
the collant light flashes when the level of the coolant is too low. may need a slight top up, thats all
My cab runs between 86 and 96 oil temp and always sits at half way or less coolant temp wise.
