Author Topic: looking to buy a 1.8T  (Read 3674 times)
Offline ozzy
« on: 24 January 2006, 08:42 »
Hi folks, newbie here, looking to change from a 325 to a Golf 1.8T (mk4), anything in particular to look out for, engine/body/recalls etc?  thanks in advance, ozzy.
Offline nadlad
  • Building Surveyor MRICS
Re: looking to buy a 1.8T
« Reply #1 on: 24 January 2006, 09:49 »
look out the boner u will get once u take it out for a spin and throttle it
<<<Big Build Thread>>>
Offline ozzy
« Reply #2 on: 24 January 2006, 10:01 »
lol, you think its going to be quicker, and that much quicker than my 325, i dont think so!!!!
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 24 January 2006, 10:15 »
A standard 150 no, but a 180 would be very close. Don't forget your tank is over 200 kg's heavier than a Mk4, & has about 190 bhp, IIRC? - Power-to-weight ratio, my friend. :wink:
My Golf was a 150, now £475 later it's 202 bhp..... I laugh at 325 drivers as I go past. :tongue: :smug: :cool:
« Last Edit: 24 January 2006, 10:28 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline ozzy
« Reply #4 on: 24 January 2006, 10:41 »
i'm going to look at a 150 hp, so it'll be close.  anyway, not here for a performance discussion between my bmw, and the Golf, was really after any proper/serious suggestions on what to look at on a mk4 Gti, thanks.
« Reply #5 on: 24 January 2006, 11:17 »
Fair enough. Common things are plastic clips on the window regulators break, window might just go clunk & stay down one day. Ask if they've ever been replaced. The new kits have the modified metal clips.
Rubber inside the re-circulation valve splits, leaving a rather loud 'chatterey' sound when you lift off the gas to change gear etc.
Water leaks through the rear headlights and/or rear wash-wipe pipe comes off. Check rear footwells & the bottom of the side comparments in the boot for water.
- Petrol cap motor seizes. Won't lock shut if it has.
I'll come back if I think of anything else.
Offline nadlad
« Reply #6 on: 24 January 2006, 12:21 »
seems liek u love ure bmw so keep it
Offline ozzy
« Reply #7 on: 24 January 2006, 12:33 »
yes i do love my bmw, and bmws in general, but im also a vw fan, i used to have a mk2 gti, and still have an air cooled bus!  just its time to replace the 3 series, and its going to be replaced by either a mk4 gti, or a newer 3 series (e46), cant decide at the mo, taking a gti out for a test drive this aft'n.
Offline APS
« Reply #8 on: 24 January 2006, 13:22 »
Well said ... after owning a Ford Cougar V6 for the last 3 years i changed to the 1.8T Mk4 (150) a little over 2 weeks ago now ... the Cougar would have eaten the Golf for breaky ... but thats not the issue .... i personally wouldnt change back now , i love the Golf ... its a lot more practical and more important more MPG !
Besides if you want performance you can always go into an aftermarket chip/re-map etc...
you wont be sorry ...
Regards APS
Golf MK4 1.8T
« Reply #9 on: 24 January 2006, 14:07 »
If you can, try & find a 180 to test drive. They are loads better than the 150 (AGU engine). Besides the extra ponies, they have VVT, a better turbo (KO3s) & a 'drive-by-wire' throttle instead of the traditional cable.
