Author Topic: Golf Stalling!  (Read 1277 times)
Offline Davo13
Golf Stalling!
« on: 23 January 2006, 22:25 »
1990 Mk2 Golf GTI 1.8 8V.
The Golf keeps stalling  quite regularly when I stop at halt signs.
Has anyone any ideas as to what it may be.  I thought it may be the fuel pump or fuel  delivery pressure.
I have changed air and fuel filters, cleaned intake manifold and cleaned injectors.  It runs fine when driving, its just when I stop.
Thanks in advance
David  :huh:
Offline Brads MK2 GTI
Re: Golf Stalling!
« Reply #1 on: 23 January 2006, 23:19 »
More than likely gonna be the ISV matey. Does it seem to drop too low on the revs when your slowing down on the brakes and drop the clutch, sometimes stalling? And is it idleing right? (Bout 800 to 1000rpm) If so take it off and give it a proper spray through with carb cleaner, leave to soak in petrol for a good few hours, repeat the carb cleaner, then a finishing touch with the WD40 caan through it to clean it even more and dry it out!
Def do this BEFORE you even think about adjusting the idle higher! You'll only be over compensating, this will lead to problems later.
Offline steviem
Re: Golf Stalling!
« Reply #2 on: 23 January 2006, 23:28 »
What happens when you stop at traffic lights instead of halt signs!!  :laugh: :laugh:
Seriously, though, it sounds like the isv
Offline [han]
  • Graphic Designer for Haribo
Re: Golf Stalling!
« Reply #3 on: 24 January 2006, 08:27 »
mine did that when it was cold? now i dont set off until its warm and im fine, but mine is a driver...
not operator misuse? lol
Offline Mr Blue
Re: Golf Stalling!
« Reply #4 on: 24 January 2006, 10:34 »
yeh clean the isv first. Ive never come across a cloged up isv myself though :rolleyes:
Look for air leaks in the vacume hoses and check the oil breather grommet for any ware - its ontop of the rocker cover
also tighten the rocker cover bolts. that worked once  :smug:
Re: Golf Stalling!
« Reply #5 on: 24 January 2006, 10:36 »
Hi Han,
Couold well have been carb iceing if it only happened when cold on a driver mate.
