Author Topic: mk3 rustspots  (Read 1563 times)
martyntzr
mk3 rustspots
« on: 23 January 2006, 20:28 »
picked up the golf on sunday just sorting out a few rust spots the worst one is on the passenger side windscreen pillar whats the best way to sort out this problem are there any chemical treatments that i can get or is it spend a saturday afternoon sanding and filling
cheers martyn
Offline GolfGL
Re: mk3 rustspots
« Reply #1 on: 23 January 2006, 20:35 »
How bad is it, is it minor and just on the surface or something quite wide and deep. Any chance you can get a picture up.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
martyntzr
Re: mk3 rustspots
« Reply #2 on: 23 January 2006, 20:39 »
it doesnt look all that deep but i havent had really good look also how do i post a photo as im a newbie
cheers martyn
« Last Edit: 23 January 2006, 22:27 by martyntzr »
martyntzr
Re: mk3 rustspots
« Reply #3 on: 23 January 2006, 22:30 »
http://129.photobucket.com/albums/c291/martyn1dsc00027.jpg
okay then the link isnt working for some reason so when you go into photobucket and go into transportation  and type in martyn1 and it should bring up the photos of the golf
« Last Edit: 23 January 2006, 22:37 by martyntzr »
martyntzr
Re: mk3 rustspots
« Reply #4 on: 24 January 2006, 14:46 »
after speaking to a few guys in work i am going to try something called kurust and then zinc prime it fill it and then paint has anyone got any experience of using kurust or any advice
cheers martyn :huh:
Offline GolfGL
Re: mk3 rustspots
« Reply #5 on: 24 January 2006, 22:37 »
Kurust is a good starting point for surface rust. Make sure you remove the flaky stuff with sand paper or something so it can work on the rusty stuff. Make sure you get rid of the rust before you start painting or it will all come back again so repeat with the kurust. Take your time with spraying it and do your prep with increasing grits of wet and dry for a better, smoother finish.
