Author Topic: Removing boot pannel  (Read 1406 times)
Offline Mr Blue
« on: 23 January 2006, 11:13 »
how do you remove the plastic boot pannel. I took 2 screws out from the grab handle areas and duno how to remove the plastic.
Need to get to the lock as its mashed and set the alarm off at night :embarassed:
Offline >>Mart<<
Re: Removing boot pannel
« Reply #1 on: 23 January 2006, 16:15 »
its held in by some metal clips which push into the boot its-self
all you need to do is give it a tug from the bottom(near the grab handles) then pull along the edges
when you put it back on make shure it is alligned near the window trim should push up then bang the trim back in
