Author Topic: Oil being forced out of cambox cover??  (Read 5742 times)
Offline Peel
  • T4 campervan
Re: Oil being forced out of cambox cover??
« Reply #10 on: 17 March 2008, 11:59 »
more likely a knacked rocker cover gasket, check the thread rubjonny stuck up about the mk3 style one that can be bought from vw for about a tenner.
Think this is my problem - and a job I should be able to do over Easter weekend. Can anyone shed any more light on the above thread please? I couldn't find it on a search. Thanks.
Golf GTI: good enough as it is
« Reply #11 on: 17 March 2008, 12:14 »
they've since fixed the silly pricing, part numbers are on the last page of the ETKA part # thread :)
http://www.golfgtiforum.co.uk/index.php?topic=33909.90
Offline Peel
  • T4 campervan
« Reply #12 on: 17 March 2008, 12:19 »
Thanks for that.
Is this a straightforward undo-replace-do up job, or are there any potential pitfalls to beware?
I'm keen but green, as Horney will testify...
« Reply #13 on: 17 March 2008, 12:30 »
only thing to note is you have to change the studs if it had a cork gasket on there before. If the studs have a shoulder they need replacing, if not they dont :)
Offline wrexham mk2
« Reply #14 on: 17 March 2008, 16:01 »
I changed my gasket over the weekend and the gasket was rubber with metal inserts, didnt fit very well at all coz of those shoulders on the studs so when i ran the engine oil pissed out everywere!!  me mum wasnt happy as it pissed out all over her drive!!  :evil: so took it apart, cleaned it up, and used a tube of gasket sealent.
touch wood it seems ok but i think im guna look at changing the studs now its been mentioned to be on the safe side
« Reply #15 on: 17 March 2008, 16:09 »
yeah the shoulderd studs stop the cover fully tightening down on the rubber gasket!
Offline Peel
  • T4 campervan
« Reply #16 on: 28 March 2008, 11:09 »
Still haven't done this!
GSF tell me they only have the cork gasket listed. Anyone know if this will do the job on my 85 K-Jet 8v?
Thanks...
« Reply #17 on: 28 March 2008, 14:31 »
look for a mk3 2.0 8v gasket, though it wont come with the new studs!
the cork gasket will do the job on the 85 unless its been converted to the later studs.
Offline Dj.Duffa
« Reply #18 on: 17 June 2012, 23:14 »
Hi did the problem ever get sorted? Im having the same sort of issue but its poss a crank seal issue!
its started leaking after I fitted TSR breather block off plates!
Offline clipperjay
« Reply #19 on: 17 June 2012, 23:22 »
Heeeeeey! holy batman this thread started 2006 till 2008 you might get a response  :lipsrsealed:
