Author Topic: poor running 2.0 8v mk3  (Read 1601 times)
Offline cohead
« on: 22 January 2006, 19:42 »
hi please help, my 96 2.0 8v has a serious running problem, at around 3500 rpm the car feels stuttery, almost like i am hitting a rev limiter. I have replaced all obvious parts even including taking a friends air flow meter, which didnt cure the problem. this is a real shame as the car is a good example and i am eager to get her back to her former self.
Offline Len
Re: poor running 2.0 8v mk3
« Reply #1 on: 23 January 2006, 10:31 »
Try the relays.
Look at that other thread you just posted in and read my post. There are other threads about this same problem as it is a common one.
www.sas.org.uk
www.the-ace.org.uk
Offline cohead
« Reply #2 on: 23 January 2006, 18:40 »
Try the relays.
Hi len, as I am not to sure about all things mechanical can you give me any more pointers, i.e where to find these sensors? I do have a friend with the same car which i can rob bits off until i find the problem, many thanks cohead.
Offline monkeyalan
« Reply #3 on: 24 January 2006, 15:25 »
the relays are hidden under the dash ,above the fuses . right of the steering wheel .
Offline Len
« Reply #4 on: 25 January 2006, 11:04 »
Phil (cohead)
Yea bit difficult to see those relays right up underneath.
Cant find it for sure but I believe that the ECU relay is E30. Try that one first. Oh and the Haynes manual aint that helpful either!
I remember what I did now - went to dealer and asked for part when I got it I replaced the corressponding numbered relay!
www.sas.org.uk
www.the-ace.org.uk
