Author Topic: dash board  (Read 1043 times)
Offline theviper
dash board
« on: 22 January 2006, 09:19 »
the little blue main beam light does not work so i took all the dash apart yesturday all that was left was the speedo cable so had a fill on the back to so if i could fill any think that i could change but couild not but on the top of the dash i have lots of varable resistors what are there for ??????????  so should i have taking the dash right out to change it ????
Pete :evil:
Offline Agreeable Slick
  • Unit
Re: dash board
« Reply #1 on: 22 January 2006, 09:41 »
you need to remove the plastic fascia around all the dials/clocks etc, I.E. pull the climate control part out and there is a screw there, one in the corner of the unit, two above the clocks, and i cannot remember where else, then the clocks will tilt forward. Unclip the speedo cable and then lift them up and out. The resistors are for all of the LEDs and MFA AFAIK, so should just be a case of getting a new led and soldering it in. (although i think they might slide in, but don't quote me on that.)
Offline theviper
Re: dash board
« Reply #2 on: 22 January 2006, 10:32 »
so i will need to solder to get the main beam light on the dash to work then
Pete :evil:
Offline ...joe
Re: dash board
« Reply #3 on: 22 January 2006, 12:21 »
not sure but mine doesn't work either, can't be arsed to take the clocks out though!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline theviper
Re: dash board
« Reply #4 on: 22 January 2006, 13:07 »
does yours go thought the MOT with it not working then ...joe???
Offline ...joe
Re: dash board
« Reply #5 on: 22 January 2006, 13:24 »
has done yeah, as long as the actual lights up front work i don't think its a problem.....
