Author Topic: Help  (Read 1181 times)
Offline Lycara
  • Smoothed doors on a driver
« on: 21 January 2006, 19:37 »
Me pump for me washers is only workin for the front and not for the back. It pumps water through the front ones but not for the back. You can hear it workin but no water reaches the back. Thre is no blockages in the pipes that i can see. Does this mean me pump is knackerd?
Thanx
Laura  :sad:
minty freash driver,with smooth doors
Offline Mew
Re: Help
« Reply #1 on: 21 January 2006, 19:58 »
Have you checked the rear hose is attached to the washer jet? This happened to me, soaked boot carpet was the major giveaway!
Offline Tim-Mk2
  • now extra wide....
Re: Help
« Reply #2 on: 21 January 2006, 20:03 »
i also have the problem but it only happened after i layed my rear wiper flat..al the pipes are connected and can also hear it pumping..sometimes it tricles out the end ut does not shoot out like it should
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline steviem
Re: Help
« Reply #3 on: 21 January 2006, 20:13 »
There are some nice people that email you 50 times a day that can help with that  :laugh: :laugh:
Offline Lycara
Re: Help
« Reply #4 on: 21 January 2006, 20:15 »
Checked all is attached and no wet boot. I guess I will just buy a new one  :sad:
Offline Tim-Mk2
Re: Help
« Reply #5 on: 21 January 2006, 20:34 »
i knew some1 would say somethin!  :grin:
Tim.
Golf Mk2 1.3 Ryder
Checkout my Mk2[/b]
Offline JMallows
Re: Help
« Reply #6 on: 21 January 2006, 22:57 »
Did you check that the hose is connected in the boot as well? Theres a few places it joins. one is obviously the pump.. and theres another in the same area. Also, remove the rubber bit between boot and car, and see the hose is intact. Might have broken where the boot has been opened many times?
A clever person solves a problem. A wise person avoids it.
Offline Lycara
Re: Help
« Reply #7 on: 22 January 2006, 10:57 »
Yup done that aswell i have no idea why it aint workin :rolleyes:
Re: Help
« Reply #8 on: 22 January 2006, 11:56 »
Have you checked behind the boot carpet on the driver side?  If it checks out there, nip to halfords and buy a 1 way valve.  splive it into the pipe in the engine bay and it will make the rear washer 'instant squirt'  :grin:
