Golf mk2
Help Me Indentify My Puddle
Topic: Help Me Indentify My Puddle (Read 1348 times)
capoot
Here all the time
Mk1 Skoda Octavia VRS
21 January 2006, 17:07 »
basically guys ive got a puddle in my drivers side footwell, any ideas? i herd it could be a heater things?
But mines working fine? Any ideas guys?
Dan
bulk66
Im broke an it aint a joke!!!!
Re: Help Me Indentify My Puddle
21 January 2006, 19:23 »
Check your front scuttle mate my last golfs drain holes had blocked up with crap. And water came in through my heaters made a right mess and it stank of old dog for months......
roverspeed
GTI forum regular
22 January 2006, 00:10 »
yup mine too, drainage holes blocked at the drivers side of the scuttle panel!
VWDino
GTI forum regular
MkII 1.6 Driver. GTi cam, K&N .....
22 January 2006, 01:17 »
Door membrane may have split or become detatched allowing rain water in. Whip off the door card and have a look.
bulk66
22 January 2006, 01:18 »
Oh have you checked your door seals.....
capoot
Here all the time
22 January 2006, 10:27 »
defo not door cards, checked those, goin check my scuttle in a mo!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
22 January 2006, 11:59 »
on the driver side it'll either be leaking in thru the bonnet release cable grommet due to blocked drains, through the vapour seals in the door cards, thru the sunroof due to blocked drain pipes, or worse through the windscreen seal.
capoot
Here all the time
Reply #7 on:
22 January 2006, 13:29 »
where will the blocked drainage be?
rubjonny
10k hero
Reply #8 on:
22 January 2006, 14:07 »
under the plastic rain tray either side are the scuttle drain areas, these get full of leaves so water starts backing up.
The sunroof drains are at the front & back of the sunroof opening, the front rubber tubes run down the a pillars and through a gap in the front wings to the wheel arch. If either of the wings have been replaced, sometimes the drain tubes get caught & pinched then the water backs up. The back ones run out into the rear arches. Pour a little water into the sunroof area and make sure the water drains out quickly
capoot
Here all the time
Reply #9 on:
22 January 2006, 16:56 »
Will do thanks!!
Golf mk2
