Author Topic: Bulbs  (Read 2347 times)
Offline the Driver
  • smell it
Bulbs
« on: 19 January 2006, 16:27 »
need some good bright bulbs for my front lights , any 1n know of any good uns , where 2 buy aswell plz
Blah blah blah Angledust
Re: Bulbs
« Reply #1 on: 19 January 2006, 16:39 »
Philips BlueVision Plus, crisp white light and not too expensive :)
Offline Brads MK2 GTI
Re: Bulbs
« Reply #2 on: 19 January 2006, 17:18 »
I'd go for Osram H4's any day. Unless it waas a day when they were out of stock and I was desperate. Then I'd go for h4 bulbs by Ring. Either way they'd be Xenon.
Offline Organisys
  • Old and Slow...
Offline rowlers
  • I'm back - MK7 GTI
Re: Bulbs
« Reply #4 on: 19 January 2006, 18:24 »
do any H4 bulbs fit a mk 2 golf???
I have an uprated loom so though I could increase abit from the standard??
Offline rowlers
Re: Bulbs
« Reply #5 on: 19 January 2006, 20:04 »
also what bulbs do the inner lamps take??
Offline roverspeed
Re: Bulbs
« Reply #6 on: 19 January 2006, 23:40 »
I think the inners are H3 iirc, don't quote me on that, they could be h1's
you can go right up to 160 watt versions on h3's  :laugh:
make sure the loom can take it, u would be best to check with dizzy.
I have them in mine, but i massively over engineered my loom, due to me blowing the crap out of my original one  :cry:
Re: Bulbs
« Reply #7 on: 20 January 2006, 02:06 »
Indeed the spotlamps are H3 type bulbs, although if you fit an uprated headlight loom and / or fit uprated bulbs, you really shouldn't need to change these. Besides, they can be a real b!tch, especially the one on the drivers side near the rad.
no need.
« Last Edit: 20 January 2006, 19:39 by The Slick Effect... »
Offline mk2_singh
Re: Bulbs
« Reply #8 on: 20 January 2006, 07:56 »
i'll back you on that. i like the retro mk2 twin lights look. When i get money i want to get cystals for the front.
Offline rowlers
Re: Bulbs
« Reply #9 on: 20 January 2006, 17:06 »
I must admit, i wouldn't change to a single lamp grill on mine!
So its h4's on the out h3s on the inner!
I made my own loom form 30 amp 2.5mm cable, so it should be able to take a good bit more than standard, if it melts it's easy enough to make another!!!
