Author Topic: A tip for mk2 golf owners  (Read 6564 times)
Offline ducatimad
« on: 12 November 2003, 22:26 »
The usual horrible winters here and some people maybe suffering from damp problems - just a tip for you - do not soak your ht system (spark plugs,leads etc) with wd40, this is a temporary measure and after time the wd40 breaks down the rubber on spark leads etc.  the remedy is to use duck oil - I am a marine engineer and always fully coat all engines with this stuff and the engines look like new and last ,ive even flipped a few boats and fully submersed engines and they have always come off ok - most off you probably already know this but i thought I would try and help anyway!
Regards to all the forum members!
Ducatimad
Offline Gambit
Re:A tip for mk2 golf owners
« Reply #1 on: 13 November 2003, 08:45 »
will it not smell like cooked duck after a burn down the motorway ;D
« Last Edit: 13 November 2003, 08:45 by Gambit »
Offline Heybatesy
« Reply #2 on: 13 November 2003, 09:16 »
Mmm crispy duck...
Is this a standard Halfords stock?
Offline Heybatesy
« Reply #3 on: 13 November 2003, 09:33 »
Duck oil that is....  ;D
Offline Helios_Blue_Valver
« Reply #4 on: 13 November 2003, 10:59 »
Haven't heard of duck oil but I will definatly give it a shot. Thanks for the tip.
free
« Reply #5 on: 13 November 2003, 11:04 »
where can you get it from? has it got a diffrent name
Offline Grovit
« Reply #6 on: 13 November 2003, 17:55 »
- Yep - I've not heard of this stuff either.........cheers for the tip though DM. :)
« Last Edit: 13 November 2003, 17:56 by Grovit »
Chris
I went to a seafood disco last week...and pulled a muscle.
Offline tinman
« Reply #7 on: 13 November 2003, 17:57 »
ducks?
Offline AdamB
  • The Perfect Storm
« Reply #8 on: 13 November 2003, 17:59 »
I think if you started to extract juice from ducks the RSPCA might get involve  :o
I don't own this anymore - I just can't be arsed to change the picture
Offline golf newbie
« Reply #9 on: 13 November 2003, 19:20 »
you can get duck oil from partco (because i work for them and you should have a local store near you as they are national)and  it be cheaper to get it from partco or any other motor factors than from  halfords ;D
